What settings of Dual Rate and Expo? https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1189 |
Page 1 of 1 |
Author: | W.W. [ Fri 19. Feb 2016 8:10:42 ] |
Post subject: | What settings of Dual Rate and Expo? |
Hello, before buying the Spirit Pro I used the Microbeast. Can you tell me, what dual rate,expo and other Settings give a similar behavior like the Microbeast in flight style "Standard"? I don't like any "bad surprises" during first flying the Spirit. best regards Wolfgang |
Author: | ZeXx86 [ Fri 19. Feb 2016 8:30:50 ] |
Post subject: | Re: What settings of Dual Rate and Expo? |
Hello, Spirit does not use any internal Expo so for the first flight you can use 20-30%. Dual Rate 100% (default on each channel). It is preconfigured for beginners so it will react rather slowly. To make it fly the most important are correct sensor compensations. It should fly similarly to Microbeast. Then you can increase rotation rates in the Sensor tab so it can rotate as fast as you wish. |
Author: | W.W. [ Fri 19. Feb 2016 8:36:26 ] |
Hello, thank you for your quick response. Then I will start with 25% expo. I have BK DS-3001HV servos (@7.4V, 0.06 sev/60°, 5.8 kg cm) on the swash plate, which servo delay do you recommend. |
Author: | ZeXx86 [ Fri 19. Feb 2016 8:45:54 ] |
You are welcome. For cyclic servos there is no Delay parameter. There is Rudder Delay for the Rudder servo, but I dont know what rudder servo do you use. Frequency on the cyclic can be configured to 200Hz. |
Author: | W.W. [ Fri 19. Feb 2016 8:56:54 ] |
It's the BK DS3005HV (@7.4V, 0.04 sec/60°, 3.5 kg cm). The cyclic servos can run at 333Hz according to the spec. best regards Wolfgang |
Author: | ZeXx86 [ Fri 19. Feb 2016 12:28:49 ] |
Yes, but generally I don't recommend using 333Hz on the cyclic, some servos are then too hot. You can set Rudder Delay between 0 - 5. |
Author: | W.W. [ Fri 19. Feb 2016 13:47:10 ] |
Many thanks, great Support here! |
Author: | Paxsman [ Sat 20. Feb 2016 22:10:32 ] |
Quote: Yes, but generally I don't recommend using 333Hz on the cyclic, some servos are then too hot. What is the recommended Hz for the BK3001HV with the following specifications...Sorry to change gears but it was kinda mentioned above. BK Micro Servo Model 3001HV Operation Voltage: 6V – 8V Weight: 20g (0.71 Oz) Torque: 3.68 kg/cm (51.1 oz/in) @ 5V | 4.7 kg/cm (65.3 oz/in) @ 6V | 5.8 kg/cm (80.5 oz/in) @ 7.4V Speed: 0.09 sec/60 @ 5V | 0.07 sec/60 @ 6V | 0.06 sec/60 @ 7.4V Dimensions: 12x23x27 mm Frequency: 1520us/333 hz Gear Type: Metal Motor Type: Coreless |
Author: | ZeXx86 [ Sat 20. Feb 2016 22:20:56 ] |
Many manufacturers are stating that their servos are rated for 333Hz, but it is not optimal always. There is very big difference when you use the servo in a glider and on the cyclic of the helicopter. The problem is, that many FBL systems are not supporting such high frequency for cyclic. So it is always good to check the temperature of all servos. Fortunately today servos are better and better. But because we have experience with this brand and pilots that tested these or other servos in a demanding situations I have putted recommendation. If you are beginner, even analog servos may survive 333Hz sometime. So it is always good to verify everything and not to be convinced just by a paper specifications. |
