It is currently Sat 23. Nov 2024 8:21:12
Post new topic Reply to topic  [ 15 posts ]  Go to page 1, 2  Next
PostPosted: Sun 14. Feb 2016 8:58:26
Does it make a difference to the piro consistency if your tail blade linkages are trailing or leading?
PostPosted: Sun 14. Feb 2016 12:57:15
As I know, Pirouette constancy only has to do with Cyclic only, tail has no influence to it if upwash, downwash, leading or trailing linkage doesn't matter to Pirouette.
Leading or tailing on Tail changes the direction of Servo. With today 3D Baldes with 0° Delta on CG there should be no difference in regards of servo force and feeling.
Head CW and CCW rotation has influence on Tail RevoMix direction.
PostPosted: Sun 14. Feb 2016 17:35:20
Not true. Piro optimisation(tuning) is meant to be tuned by watching the swash. Piro consistency is the tail I gain. Higher value = tail holding its position more aggressively. Too high value will cause slow wide tail wag.
For the OP, it makes no difference to tail blade linkage type.
PostPosted: Sun 14. Feb 2016 18:43:31
I didn't think it would.
I have my tail locked in with gov turned off, rust using a slight v curve but when I turn the gov in my esc on the tail kicks to the right when I pitch up. I tried raising the piro consistancy and got it up to 195 and it still did it. What should I be looking at to make it hold.
Esc is yep 120hv and 12deg pitch.
I have raised the head speed to no avail also.
PostPosted: Sun 14. Feb 2016 21:04:42
Ups I mixed it up sorry.... :oops:
It looks like your Gov is loosing rpm under load. Keeping rpm is critical, if possible tune ESC PID-Parameters.
I-Gain (Piro consistency) is more for moderate climbs descents as well as CW and CCW Piro consistency on FF.
For aggressive pitch maneuvers, you might need to look into RevoMix. I have got mine at 2.
Check direction by pushing full pitch on the bench, you see small tail move which helps to keep position.
PostPosted: Sun 14. Feb 2016 21:35:36
Gov is holding a constant head speed. More constant that I had it with just curves.
PostPosted: Sun 14. Feb 2016 21:36:47
Have you tried with Revo Mix?
PostPosted: Sun 14. Feb 2016 22:00:32
It sounds like you've not setup your tail mechanics properly. Without the gov the head was loosing speed allowing the gyro to catch up and compensate. Try adding a bit more anti torque by twisting your ball link a couple of turns. Re adjust end points and give it a flight. Revo mix should not be needed if the tail is setup properly mechanically.
PostPosted: Sun 14. Feb 2016 22:10:00
Thanks I'll give that a go. I did read revo should be last resort so thought I'd see if there may be another solution first
PostPosted: Tue 16. Feb 2016 5:11:01
I haven't had a chance to test yet but what about dropping the tail delay, would that help in that situation/
Users browsing this forum: No registered users and 32 guests
