It is currently Sat 23. Nov 2024 11:31:31
[ 3 posts ] |
W.W.
Posted: Fri 05. Feb 2016 15:12:23 |
Joined: Mon 01. Feb 2016 13:37:12 Posts: 65 Location: Germany
is it possible to set the Spirit up with a different RX (RSat or R9EX) than the RX, which will be used in the helicopter? Or do I have to redo the adjustments of the servo travel?
I wan't to replace another FBL-System in my helicopter and want to play around with the Spirit and the Jeti Integration first, before flying. I think, with digital signals like SRXL/SUMD/UDI/EX-Bus the values shouldn't Change with a different receiver.
I will go through the settings anyway but want to know whether I shold invest the time in adjusting servo travel ... precise when playing around or if I should save the time and do this in the model.
best regards Wolfgang
_________________ regards Wolfgang
My Helis: Walkera 4G6 2S µBrain, Align T-Rex 250 FBL Microbeast, Oxy 3 Spirit Pro controlled by Jeti DS16
Posted: Fri 05. Feb 2016 15:31:45 |
If you are changing receiver, but used protocol (for example EX Bus) is same, then everything should be same. So you do not have to reconfigure anything.
W.W.
Posted: Fri 05. Feb 2016 15:54:26 |
many thanks, great support and fast answers here!
[ 3 posts ] |
Users browsing this forum: No registered users and 49 guests |
