It is currently Sat 23. Nov 2024 8:49:44
 Post subject: Spektrum Telemetry
PostPosted: Mon 08. Feb 2016 23:53:26
Has anyone used Spektrum telemetry with the spirit running Spektrum satellites?
 Post subject: Re: Spektrum Telemetry
PostPosted: Tue 09. Feb 2016 0:43:29
You mean the spirit has 2 satellites, and you have a TM1000 telemetry unit?
You can use it this way. Just need to bind them at the same time. The only disatvantage is in this way, that you can't get the radio link quality feedback (fades, holds). But you get all other things, like rpm, RX voltage, flight pack voltage, temperature etc.
PostPosted: Tue 09. Feb 2016 10:57:16
Yes, I use it like that. No special requirements, just unplug the signal wire between Spirit and TM1x00, otherwise you will get some funny random readings in Receiver telemetry (which you will NOT have, as Gtamas said).
Also, no need to bind them at the same time, that's kind of a urban legend - I did not even rebind the TM1x00 after swapping from AR7200BX to Spirit and satellites ))))))))))))
Users browsing this forum: Bing [Bot] and 31 guests
