Spirit System
Setting Spirit up with different RX (EX-Bus)
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1172
Author:  W.W. [ Fri 05. Feb 2016 15:12:23 ]
Post subject:  Setting Spirit up with different RX (EX-Bus)
is it possible to set the Spirit up with a different RX (RSat or R9EX) than the RX, which will be used in the helicopter? Or do I have to redo the adjustments of the servo travel?
I wan't to replace another FBL-System in my helicopter and want to play around with the Spirit and the Jeti Integration first, before flying.
I think, with digital signals like SRXL/SUMD/UDI/EX-Bus the values shouldn't Change with a different receiver.
I will go through the settings anyway but want to know whether I shold invest the time in adjusting servo travel ... precise when playing around or if I should save the time and do this in the model.
best regards Wolfgang
Author:  ZeXx86 [ Fri 05. Feb 2016 15:31:45 ]
Post subject:  Re: Setting Spirit up with different RX (EX-Bus)
If you are changing receiver, but used protocol (for example EX Bus) is same, then everything should be same. So you do not have to reconfigure anything.
Author:  W.W. [ Fri 05. Feb 2016 15:54:26 ]
many thanks, great support and fast answers here!
http://www.phpbb.com/
