It is currently Wed 27. Nov 2024 2:20:40
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sun 04. Oct 2015 21:06:40
Both updated with timer for acro mode rescue.
Thanks Tomas.
PostPosted: Sun 04. Oct 2015 21:12:32
That was fast!
Diky Tomáš !
PostPosted: Mon 05. Oct 2015 12:31:35
Great turn around time! Thanks Tomas!
PostPosted: Mon 05. Oct 2015 12:49:31
The timer is defaulted at 0.1s
PostPosted: Mon 05. Oct 2015 14:05:57
Hi Tomas, is there going to be a 1.3.1 file for the Jeti system? Thanks
PostPosted: Mon 05. Oct 2015 16:29:03
do I understand this right ?? , normal mode works as it did but with a adjustable timer ,that limits climbs out to time limit then switches off bailout. ?
acro mode will level to either way up which ever is quickest climb out to set time limit and if its inverted flip to skids down when time limit reached ?
not that I can find a timer in acro rescue mode , why does it not also have timer
PostPosted: Mon 05. Oct 2015 16:52:05
No.
Normal mode will level to inverted if it's faster, climb up for the set time, then flip skids down and keep climbing until turned off.
Normal mode when leveling to normal and Acro mode are both unchanged.
PostPosted: Mon 05. Oct 2015 17:05:48
Coco66 wrote:
No.
Any one know the delay for the flip when in normal mode? I have rescue set to acro but want to try the normal rescue + flip. I've got it on a momentary switch so I'm curious to know how long I need to hold it down.
PostPosted: Mon 05. Oct 2015 17:17:16
thanks ,so there is no point in having acro mode rescue now then if normal mode corrects your inverted mistakes
PostPosted: Mon 05. Oct 2015 17:44:01
just push and hold until it flips, the time until it flips is what you set it to.
MyRCode wrote:
Coco66 wrote:
No.
Users browsing this forum: Bing [Bot] and 2 guests
