It is currently Sat 23. Nov 2024 8:17:29
PostPosted: Sun 13. Dec 2015 5:56:43
I recently got a dx9 as a upgrade from my dx8 and ive got it all binded to my g380 fine and working properly with very little adjustments. Switching the radios on the heli was surprisingly very easy but I came across an issue w the gyro channel. I cant seem to get it to match w what my tx reads. On the diagnosis page they will start out reading the same but the higher I get, say around 20 they start to differ by one or two points. By the time I get to my desired gain, the difference is like 20. My tx will read like 87 or so and the diagnosis page reads at 76ish. What can I do to fix this?
PostPosted: Sun 13. Dec 2015 6:24:07
Adjust your travel end points for gyro till you get a 1 to 1 ratio thats what i did with my dx9. So a value of 60 gyro gain in tx will give me 60 in diagnostics page
Compass 7hv v2 spirit pro. Compass 7hv v2 spirit pro. Trex 550fl spirit. Heli-x sim. NeXt sim. Pheonix sim. Fms p51 1400 spirit. Coolice 2400watt psu. Pl6. Icharger 206. Peter lynn twister 5.6. Dx9. TM1000.
PostPosted: Sun 13. Dec 2015 6:28:08
How could you do that through the diagnosis page without having to adjust the gyro gain seperately then going back to the diagnosis page to see if it worked or not?
PostPosted: Sun 13. Dec 2015 6:56:07
Ah, ok I got what you ment. I went back and did it that way and was able to get it to a ratio of 1:1. Everything checks out now. Thanks!
Users browsing this forum: No registered users and 42 guests
