How to hookup bluetooth to red unit https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1086 |
Page 1 of 1 |
Author: | Alyon187 [ Wed 09. Dec 2015 9:00:29 ] |
Post subject: | How to hookup bluetooth to red unit |
Ive got a spare generic bluetooth that I used on mt vbar and believe will work but I dont know where to connect what pins. Ideas? |
Author: | Alyon187 [ Thu 10. Dec 2015 3:16:45 ] |
Post subject: | Re: How to hookup bluetooth to red unit |
Ok thanks Tomas. I went ahead and ordered a bt module from you guys. One more quick question, ive got a hw 100a v3 on my goblin 380 and only use the throttle/bec cable connected to the red unit so ive got the other bec cable just secured to the frame. Could I use that extra cable to power the bt unit and then the other bt connector to the system port? |
Author: | ZeXx86 [ Thu 10. Dec 2015 8:18:50 ] |
Yes, this will work fine. You will only need adaptor to connect both servo cables together, because both are with same end. |
Author: | Adrian [ Thu 10. Dec 2015 9:04:44 ] |
use a servo V-cable. Edit: Y-Cable |
Author: | Alyon187 [ Thu 10. Dec 2015 13:48:49 ] |
Thanks Tomas. Do you mean a Y cable? Never heard of a v cable. |
