Spirit System
Different collective value for banks 1 & 2
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1077
Author:  Alyon187 [ Sat 05. Dec 2015 23:25:23 ]
Post subject:  Different collective value for banks 1 & 2
When I setup my bankswitching today after I maidened my g380 yesterday I activated it in the channels tab to channel 7 (dx8 w sats by the way) then turned on my gov selection in the tx and checked against the diagnosis tab so that bank 0 was at my pos 0, bank 1 w pos. 1 and bank 2 w position 2. But when I switched from bank 0 to bank 1 I noticed my swash would pop up to a different spot. So I checked the settings and noticed that my collective slider was at like 70 or sometging close to that while bank 0 was set at 170. I didnt change this and non of my other setup parameter settings changed between the banks I.e. tail end points, cyclic ring etc.shouldn't my collective slider be grayed out like the other setup parameters?
Author:  ZeXx86 [ Sat 05. Dec 2015 23:34:43 ]
Post subject:  Re: Different collective value for banks 1 & 2
collective pitch parameter can be different between each bank, so it is necessary to configure it to the same value for each bank in your case.
Then it will be OK.
Author:  Alyon187 [ Sat 05. Dec 2015 23:48:49 ]
Oh ok, thanks Tomas. i did go ahsad and change the collective slider on banks 1 and 2 to match the same number on bank 0.
Id like to say so far im very happy w yalls system. I maidened my g380 yesterday and it flew great so far. A lil soft on the cyclic but im upping the cyclic feed forward to 8 to see if that helps at all. Other wise piros seemed on spot, heli raises straight up w hard collective hits, tracking looks perfect. Loving it so far! Thanks for the great system.
Author:  ZeXx86 [ Sat 05. Dec 2015 23:52:30 ]
Perfect,
thank you too!
You can play with Cyclic Feed Forward and Flight Style (higher values).
http://www.phpbb.com/
