Spirit System
Goblin Gasser - Pull the trigger or not?
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1045
Author:  FrankFuss [ Fri 20. Nov 2015 22:01:07 ]
Post subject:  Goblin Gasser - Pull the trigger or not?
I love the Spirit on my T-Rex 450Ls and the Spirit Pro on my Goblin 500, but have not reallty tried the Spirit governor since I have good luck with the Hobbywing ESC governor. I am thinking about a Goblin 700 Gasser and would want to use the Spirit governor with the Stator Gator RPM sensor. Is it likely that this combination will work well, or should I hold off for now?
Author:  Scott H [ Sat 21. Nov 2015 13:31:31 ]
Post subject:  Re: Goblin Gasser - Pull the trigger or not?
As I mentioned on HF I have not tried 1.3.2 yet and will update after I do try it this weekend. I did not mention though that I'm not using the Stator Gator. so I won't be able to help with that aspect.
Author:  ZeXx86 [ Sat 21. Nov 2015 13:36:07 ]
Stator Gator is designed to work with Futaba Governor which require special inverted signal. With Spirit it should work as well, but it could be necessary to invert the signal with S-Bus inverter.
So at the moment we can't guarantee that it will work.
http://www.phpbb.com/
