Spirit System
Update firmware
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1040
Page 1 of 2
Author:  Mrdo [ Wed 18. Nov 2015 17:52:34 ]
Post subject:  Update firmware
Now i get problem. i try to update the Spirit and now I can not connect to it, even the red lamp is not light. somebody has a solution?
Author:  ZeXx86 [ Wed 18. Nov 2015 17:57:29 ]
Post subject:  Re: Update firmware
yes, there is solution.
Can I ask you, if the LED on the unit blink for very short time when you connecting the battery?
Or is LED always OFF?
Can you tell me what is your operating system and if you have installed driver that is in the installer (in case of Windows)?
Author:  Mrdo [ Wed 18. Nov 2015 21:05:01 ]
Led is always off
My opering system is Windows 10 Pro
Author:  ZeXx86 [ Wed 18. Nov 2015 21:30:43 ]
Ah, in this case I will send you Guide that will describe how to solve the problem.
I will send you the guide in the private message.
If there is short LED blink, then it is possible to fix it very easily, but as you have said LED is always off.
Author:  Mrdo [ Thu 19. Nov 2015 15:04:02 ]
The led is always of
Best regards Daniel
If you always tell the truth, you never have to remember what you had said.
Author:  Coco66 [ Thu 19. Nov 2015 15:09:42 ]
Best regards Daniel
Of course ZeXx86 meant to say "is always off" but wrote "is always on".
Author:  ZeXx86 [ Thu 19. Nov 2015 16:28:29 ]
Indeed.
Author:  Anton [ Sun 04. Oct 2020 7:36:48 ]
Hi guys,
I have unsuccessful firmware downgrade and I can't connect to my Spirit Pro.
The LED on the unit blink constantly.
I have win8.1
I have installed the driver that is in the installer.
I have tried to enter into "Recovery Mode" but the software did not prompt for Demo mode, just silently shows me the spirit logo.
Can you help me?
Author:  ZeXx86 [ Sun 04. Oct 2020 8:53:27 ]
what firmware you have flashed?
Constant blinking is very uncommon behavior.
Can you try to wait few minutes if maybe unit will finish initialization?
You can connect Spirit Settings only if LED light is steady on.
http://manual.spirit-system.com/index.p ... ing_Failed
Author:  Anton [ Sun 04. Oct 2020 10:19:43 ]
Two days ago I occasionally found spirit-fw-3.2.0.4df on your site and decided to try it.
I updated to it without a problem, took a look at it, and decided to downgrade to officially released version 3.1.0 but it did not allow me to downgrade.
I deleted the software v3.2.0, installed v3.1.0, and tried to update the unit to spirit-fw-3.1.0.4df.
When I clicked on the button 'flash' the process hanged. I was waiting for about 2 minutes without any progress and I switched off the power of the unit. That is all.
The LED is blinking with frequency ~ 2Hz.
I waited about 10minutes but nothing changed.
http://www.phpbb.com/
