How to power the red fbl unit https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1018 |
Page 1 of 1 |
Author: | agh321 [ Wed 04. Nov 2015 19:43:02 ] |
Post subject: | How to power the red fbl unit |
I've got my pro version set up and flying ok without gov ??????????? Any way it's time to set the RED version up Problem is I want 2 sats to work so I've only got the aux and rud channels spare But the second sat will only work in the rud channel so that only leaves the aux ch for The power lead from my 6.6v life It keeps referring to 2 power inputs to power the fbl unit but I've only got one Believe me I've tried every option to power the unit with 2 inputs and y leads to take the second sat but the sat won't initialise on a Y lead and /or I've got no throttle . So it leads me to believe the sat can only go to the rud channel and power on a Y lead with throttle goes to the aux channel So is 1 power lead via a Y lead ok and safe to fly |
Author: | ZeXx86 [ Wed 04. Nov 2015 23:20:17 ] |
Post subject: | Re: How to power the red fbl unit |
Hello, you can connect secondary satellite to the RUD port only. Throttle must be connected to the AUX. If you will use Y-harness, you can connect battery to the RUD (second free Y-harness cable). In this way, it will work without any problem. If you will need second power input, you can also use second Y-harness in the AUX. If you are using classic receiver connection, then there are two power leads so you are feeding the unit from receiver. It is not safe to use only one port for powering. |
