It is currently Sat 23. Nov 2024 3:56:14
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: 1.3.1 failure
PostPosted: Thu 15. Oct 2015 16:26:15
What Do I do next?
PostPosted: Thu 15. Oct 2015 17:00:23
When your LED blinks for a while, then only you have to do is:
1. Start the software and then press No when prompted to Demo mode.
2. Select the firmware in the Update tab and press the flash button (you should see Recovery mode label immediately).
3. Connect the battery to your model (with USB interface connected). Then you should see a new flashing progress.
PostPosted: Thu 15. Oct 2015 18:04:15
If it doesn't, what should I do?
PostPosted: Thu 15. Oct 2015 20:45:19
It does not blink...what do I do??? This is getting frustrating.
PostPosted: Thu 15. Oct 2015 20:47:47
It is not a problem. I will send you the guide in the private message.
PostPosted: Thu 15. Oct 2015 20:56:41
Did you send it?
PostPosted: Thu 15. Oct 2015 20:57:29
Yes.
PostPosted: Thu 15. Oct 2015 20:58:58
Pls check your pm...
PostPosted: Thu 15. Oct 2015 21:19:14
How long should the recovery take?
PostPosted: Thu 15. Oct 2015 21:20:31
Once the unit is plugged in?
Users browsing this forum: Bing [Bot] and 49 guests
