It is currently Sun 24. Nov 2024 10:24:53
Post new topic Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
PostPosted: Wed 05. Aug 2020 23:46:18
jjuk wrote:
IIRC rescue does not override RTH.
If rth is enabled, rescue does nothing.
I cant check this for a while as I crashed that heli yesterday (battery came unplugged lol) but that's what I remember happening.
Do you have a spirit red and geo in a heli that you can check this?
I'm waiting on parts for a few weeks now.
Tested it today it does work.
Activated RTH model starts Home
Activated Rescue model levels out and goes up.
Released Rescue model resumes travel to home point.
PostPosted: Thu 06. Aug 2020 2:48:40
jjuk wrote:
A simple massive improvement would be the ability to set the RTH height in the RTH settings. Having to control the altitude of a heli I can only just see is not ideal.
RTH, for me, is used when the heli is so far away I can no longer work out orientation.
I totally agree, instead of having to use 2 channels at the same time 1 = RTH and 2 = Altitude hold.
I like being able to set the altitude
Or being able to turn RTH and Altitude hold at the same time in one channel so you can vary the altitude if you need.
PostPosted: Thu 06. Aug 2020 9:39:17
You can do that by setting RTH and alt limit on the same switch.
It would return at the height it was at when you enabled the switch.
 Post subject: Return to home altitude
PostPosted: Thu 06. Aug 2020 12:16:45
Hi jjuk,
I tried RTH and Alt limit on my small testing heli a 230S with uSpirit a few weeks ago and it blocked my controls when I tried it on the ground.
I posted if it was normal and had no answer. I have a ESC problem with tha test heli and I don’t want to try it on my 380.
I do like the scenarios proposed with the steps, it’s guaranteed to work and be supported.
Users browsing this forum: Google [Bot] and 63 guests
