ZeXx86 wrote:
First from all, please do not look at the servos at all, yet.
Only when you will see correct response in the software, then radio setup is done and you should not touch channel reversing in your radio. And then you should check your servos. But no adjustments to radio are needed in regards to channels once they are properly set according software diagnostic (bar movement), even if you will see incorrect servo movement. All will be set in the software regarding servos.
In the Step 5 or Diagnostic tab, just make sure all channels are moving properly and in right direction.
With Default channel layout in unit and radio it should work out of the box.
The only thing you have to do is to:
Assign Throttle function to Channel 1. Not to AUX1. Channel 1 is channel from radio. Not output port of the unit. Output port for ESC is always AUX1. But input channel can be different. But for Spektrum and the most other radios you should select just Channel 1.
That is all what you have to do.
So assigned channel's column will look like:
1, 2, 3, 4, 5, 6
OK, I can't upload pictures, not clear why, so I will try to explain it in words:
1) In step 5 I have the following:
Throttle = 1% stick down
Ruddedr = 0% middle
Pitch = -96% stick down
Eelevator = 1% stick middle
Aileron = 0% stick middle
2) Receiver channel mapping : 1,2,3,4,5,6,7 - All moving the correc direction
3) Step 6 CH7 reversed, Collective direction reversed, Cyclic and rudder directions are correct (see comment below)
4) Step 7, swash plate leveled OK and pitch stick moves in the right direction.
Not clear what should I do to have it level zero degrees? I check the box "Pitch Adjustment" and move any of th cyclic group, up or down, to get pitch at Zero degrees? and at this poing CTRL+S got the message it is saved. Is this OK?
Checked on both blades and made sure they are both Zero pitch
5) When I move to Step 8, the swashplate tilts to the right, the front blade goes into negative pitch.
If I move the Ailrone stick right, the swash plate move to the right, move left - it moves left.
BUT - To get this to work correctly - I have to have the Ailrone channel on my Radio to be reversed. If it is NOT reveresed - the ailerone activity is the wrong way.
So, what do I do now? How can I send you some screen images?
Thank you
