It is currently Mon 25. Nov 2024 2:35:34
Post new topic Reply to topic  [ 13 posts ]  Go to page Previous  1, 2
PostPosted: Thu 09. May 2019 8:49:25
Thank you for response xokia.
Hopefully Zexx can answer the rest of the questions, then maybe your request with rudder delay will be solved too. :)
PostPosted: Thu 09. May 2019 10:40:53
1) If you can observe extremely fast oscillations then Rudder Delay is likely too high. In range of 0 - 3 you will rather not notice any difference.
3) Yes, it is all described in the manual and also when you will hover mouse cursor above a parameter.
4) If Governor is reacting too agressively then it has a negative impact on the tail. So if gains are too high, it will cause tail to perform poorly, since motor is making a bigger kicks.
I would set a higher RPM, maybe 3000 RPM.
3) You are right, but in a normal circumstances it is not needed. Especially if the model is built correctly according the manual.
Can you observe a tail hunting during hovering when there is no wind? This is good thing to check. If it is apparent, then the mechanics is still not moving smooth enough.
I am afraid, but KST 215 is not designed as a tail servo. Even that speed is good a slower tail servos could perform better.
Rudder Delay can't be configured according servo speed. Each servo is different and require a different values. Even if the speed is very same, the values could differ a lot. So that model can fly well and other can oscillate badly in fast forward flight.
PostPosted: Thu 09. May 2019 17:49:32
Thank you for your response.
There is no tail hunting during hover and my tail servo is not a KST215 its a MKS HV93i.
Thank you also for clarification of rudder delay, at least i now know at what to look at with a bit detail.
Users browsing this forum: Bing [Bot] and 72 guests
