It is currently Sun 24. Nov 2024 13:11:38
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Governor problem
PostPosted: Mon 09. Apr 2018 16:28:50
Hello!
I have same problem, but reflashing doesnt help. What could I do?
Thank you for answer.
Best regards Tine
PostPosted: Tue 10. Apr 2018 7:20:26
could you describe your setup completely please? Also please send your settings.
At the moment we have no information from you so it is very hard to help.
PostPosted: Wed 11. Apr 2018 15:15:47
I have on trex700 nitro. Sensor is from align with two magnets installed in clutch bell. My max speed is set to 2000rpm, trothle curves are set to 80 and 90%, but headspeed is always 1980 rpm. If I change gear ratio, governor response, max headspeed,...headspeed is always 1980rpm. In software is everything ok: target speed, magnets are active or inactive, rpm are changing if I spin clutch bell.
PostPosted: Wed 11. Apr 2018 16:11:23
Thanks for the info.
Are both magnets oriented in the same direction?
Is 1980 RPM reading real or you think the value you can see is incorrect?
Could you also share your settings please?
When you are trying it, is the Collective pitch in the middle? Did you tried it with blades on or it is just from the bench testing?
PostPosted: Wed 11. Apr 2018 19:20:57
Can you write down your throttle curve values ? If throttle value that spirit takes from receiver changes after governor engages ( not like flight mode change, like throttle stick moves and throttle value changes) , then governor start to react weird.
PostPosted: Thu 12. Apr 2018 7:14:12
Hello
1980 rpm are real in flight and on the ground with half stick. Thr curves are flat 80 and 90%. Settings are default, if i change settings nothing changes. With wifi connection in software show 1980rpm in hover.
PostPosted: Thu 12. Apr 2018 8:40:02
Tinek wrote:
Hello
Okay, I understand but it can really be about your throttle curve values. How do you spool up from idle? By releasing hold at "idle up" mode or spooling up with normal mode then switching to "idle up" flight mode?
If you write down throttle curve values it will be very useful to solve this, IMHO.
PostPosted: Thu 12. Apr 2018 9:10:59
I spool up in normal then switch to idle up.
Idle1 flat at 80%
Idle2 flat at 90%
PostPosted: Thu 12. Apr 2018 9:16:50
Please try to use Governor to spool it (from idling) instead of using any other throttle curves. I believe it will help.
PostPosted: Thu 12. Apr 2018 9:40:22
Tried that too, but it was the same.
Users browsing this forum: No registered users and 87 guests
