It is currently Tue 01. Apr 2025 1:45:44
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Sat 28. Mar 2020 20:16:02
I have a question about whether it's OK to put 3.3v into the SYS port? I read on the Spirit System's Manual online that you should NEVER put voltage into the SYS or AIL/ELE/PIT port either. But when I hook up the FrSky Integration Cable to my XSR and add voltage to it from AUX1 on Spirit Pro, it shows 3.3v output on the red side of the cable. Is this OK?
PostPosted: Sun 29. Mar 2020 20:17:15
Usage FrSky integration cable is - of course, correct.
If you will use it as described in the manual, there will be no issue.
Connecting anything else could result in a bad outcome.
3.3V is signal voltage.
PostPosted: Thu 25. Nov 2021 10:29:42
Hello ,
for r-xsr or archer rs without integration cable !
Thanks Supporter ZeXx86
PostPosted: Sat 15. Oct 2022 8:35:16
@ZeXx86 Is the post and diagram from erti74 correct ? I can just buy the r-xsr receiver and wire it according to the picture and get telemetry from the spirit unit?
PostPosted: Sat 15. Oct 2022 8:40:12
it should work.
PostPosted: Thu 28. Mar 2024 15:44:42
erti74 wrote:
Hello ,
i traid to conect we these wiring diagram but the System WIzard told me is no soporte for microspirit::
I need help about. Wich receveir can work with radio master tx16 and micro Spirit??
PostPosted: Thu 28. Mar 2024 20:58:36
This receiver has support only for SBUS or FPort. Both are supported by microSpirit.
Users browsing this forum: No registered users and 8 guests
