It is currently Sun 24. Nov 2024 1:56:02
Author |
Message |
gerry
Posted: Mon 05. Jun 2017 7:01:14 |
Joined: Fri 26. Aug 2016 6:51:10 Posts: 227 Location: Austria
Hello Tomas! Have tried all possibilities.But no result! Please, after examining the problem, send the settings for Cosmic and for Spirit, Thank you! Greetings, Gernot
_________________ Greetings from Gernot
Top |
gerry
Posted: Wed 07. Jun 2017 15:10:17 |
Hello Thomas. Do you know something new because of RPM at the Kosmik?
Top |
Posted: Thu 08. Jun 2017 9:37:28 |
Site Admin |
I have found that there were some issues with RPM also with JLog from certain update. The fix was to set Motor Pole to 2 and to leave default gear ratio in the Kosmik - 1:1.00.
In case of Spirit I recommend to set Gear Ratio according to your model (in the Spirit Settings) but to change Sensing Divider to 4 there. So changing sensor divider should do the trick.
Top |
Who is online |
Users browsing this forum: No registered users and 38 guests |
