It is currently Fri 22. Nov 2024 14:04:31
[ 2 posts ] |
scornflake
Posted: Mon 01. Jun 2015 2:11:51 |
I'm having trouble setting up the gov for Nitro on an N7. Im using RJX as my throttle servo, FS0521HV.
The problem is I cannot tune the Spirit to give me 0-100. If I get the min tuned so that it hits the low throttle stop on the engine, I can't get the max to hit the top throttle stop. The servo stops responding once there's a > 20 point adjustment. i.e: I can't tune min below -80 and I can't tune Max above 120. In trying to do so, there is no longer further movement/adjustment occurring at the servo.
So far this means while I can adjust to get a correct zero/min throttle position, I can't get the high throttle set (it's quite a bit off, prob 5mm away at the carb itself).
Should I just adjust end points to counter this? If I do that will that confuse the gov in the Spirit?
Posted: Mon 01. Jun 2015 8:15:31 |
you can change travel adjust in the transmitter freely. Then it should match fine.
[ 2 posts ] |
Users browsing this forum: No registered users and 36 guests |
