It is currently Fri 22. Nov 2024 13:31:06
Post new topic Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
 Post subject: Re: X3 Spirit setup
PostPosted: Wed 15. Apr 2015 21:40:18
Yes, you can try to decrease Cyclic Gain little bit.
PostPosted: Sun 26. Apr 2015 16:08:21
So today I had some time to look into my tail issue.
From day one it gives me a CW piro stop bounce. (Never seen with my VBar.)
(CCW is perfect stop.)
I added some degrees offset by shortening my tail push rod by two full turns.
Must be something like 4 or 5 degrees.
I recalibrated rudder end-points using the software.
(Initial settings with zero offset 150-150.)
New settings file is attached.
I was a bit disappointed, the CW piro stop bounce got worse. :shock:
For the next flight I changed rudder offset to 2 or 3 degrees or so.
(Lengthen push rod with one full turn.)
We will see...
X3.4ds [255 Bytes]
Downloaded 42 times
PostPosted: Sun 26. Apr 2015 18:23:10
It is important to set the angle to correct side. Your tail slider should go closer to the tail boom.
You can also try to decrease Piro concistency little bit (to 160), it will help too.
Also make sure that the servo horn is at 90° when Subtrim (tuning) is enabled.
PostPosted: Sun 26. Apr 2015 19:29:44
Yes, I sure did set the slider closer to the tail boom.
(Compensate rotor torque.)
The servo horn has always been at 90°.
I'll try Piro concistency as well, not really played with that number.
Users browsing this forum: Bing [Bot] and 35 guests
