It is currently Fri 22. Nov 2024 8:05:56
PostPosted: Mon 20. Apr 2015 23:43:53
I have been working on the tuning of a Goblin 380 (I am using it with a Jeti DS-16).
I have lowered the Rudder Gain Sensitivity down to 30 in the transmitter which seems to be just about perfect, and has eliminated all signs of the tail wag that was there with higher settings.
There is still just a hint of tail kick to the right when applying full collective (Pitch Pumps). I am thinking this would be something that Rudder Revomix would address, but I'm not sure whether to use a positive or negative value for the Pre-Compensation, or how much to use.
(The Goblin Main Rotor turns in a clockwise direction)
Thanks for your help,
Brian Tracey
Santa Fe, New Mexico, USA
PostPosted: Tue 21. Apr 2015 9:30:39
it is needed to configure Piro Consistency parameter to get proper holding performance.
You can start with value of 160. It shouldn't be more than 170 for your helicopter.
What is your rudder servo? Can you attach your settings, please?
Users browsing this forum: Bing [Bot] and 30 guests
