It is currently Sat 21. Sep 2024 6:29:48
[ 3 posts ] |
Toshhairyfool
Posted: Fri 26. Dec 2014 21:15:45 |
Hello all Looking to wire my first Spirt and wanted to double check I get it right. I will be using two Spektrum satalites, a bug, a bec and a Castle ice 100. I have removed the White, red and black wire from the castle esc and put the Orange signal wire in with the red and black wire plug from the bec which will go into the Aux channel. I will use a y lead in the Rud channel one side the satalite adapter wire the other the bug. Does this sound correct? Also on my dx8 in the gyro tab I have +60 0 -60 is that a good starting point? Many thanks for for help
Posted: Fri 26. Dec 2014 21:29:48 |
it is possible it will work, but your ESC could require to share Ground signal with your BEC. But in case you are powering BEC with same battery as your ESC, then it should work.
I recommend to use Gyro gains +55% +65% +75% to start with.
Toshhairyfool
Posted: Fri 26. Dec 2014 22:01:10 |
Thanks for the quick reply, yes the esc and bec are powered of the same 6s lipo
[ 3 posts ] |
Users browsing this forum: No registered users and 46 guests |
