Could someone please explain to me the diagram for vibrations? The peaks I see in the diagram do not keep up with the single value on the right. The peaks always seem to be way higher. Like this example in the photo where peak seems to be at ~58 while it says OK=46
Also I'd like to know how the Hz on the X axis correspond to rpm's. I mean, ok, apparently from manual someone understands that if you can see vibrations up to 500Hz or 30,000 rpm, the one I see here at ~220Hz should be around 13,200 but what are these 500Hz? What do they correspond to and why 500Hz is 30,000 rpms?
