It is currently Fri 22. Nov 2024 1:35:12
 Post subject: [SOLVED] ppm and jeti tx
PostPosted: Sun 07. Sep 2014 23:55:05
I have a question, Since I have to use a port on my jeti r3 rx for the throttle this means I could set the ppm+ output on my r3 rx to 5 channels. So if I set it to only 5 channels do I still need to use 25ms for the rx ppm output. Or is 25ms only needed with 8 channel ppm into the spirit?
Thanks in advance,
Scott.
 Post subject: Re: ppm and jeti tx
PostPosted: Wed 10. Sep 2014 19:45:02
Looks like I am not going to get an answer on this one LOL!
PostPosted: Wed 10. Sep 2014 20:19:09
Sorry, I dont noticed your question.
It is recommended to use 25ms for PPM for current version in all cases.
For current version it will not work with 5 channels only (because of lack of gyro channel), for the following version it will be possible.
PostPosted: Thu 11. Sep 2014 2:33:03
Thanks Thomas. I guess we with jeti and using mui's will just have to be patient with jeti to get us an expander that will communicate telemetry and exbus so we can utilize the spirits exbus protocol!
PostPosted: Fri 12. Sep 2014 13:20:59
Or maybe the Spirit can support UDI which is also a great protocol that Jeti and many others support :-)
Users browsing this forum: No registered users and 41 guests
