ZeXx86 wrote:
the settings are not loaded in Demo mode only in 3.6.2, because there are bigger differences inside from 3.6.1.
However in 3.6.3 it will work again.
With connected unit you can load settings normally with all versions.
Thanks Thomas for the reason,
Will the old files be upgraded when loaded in the 3.6.3 version or I should keep a old win version if I want to o back and check a setting. I really use that feature to see changes it my settings.
Envoyé de mon iPhone en utilisant Tapatalk
