It is currently Fri 22. Nov 2024 18:34:25
PostPosted: Sat 27. May 2023 8:16:28
Hi all,
i installed the above mentioned components in one of my Helis (Goblin 500) using the Spektrum SRXL2 cable and the SPM4651T as primary receiver. All components are running the latest software; nevertheless, after following the Spektrum Telemetry Integration setup guide on spirit wiki, the integration menu is NOT shown in my NX8. Intial setup and configuration of Spirit GT precessed without any issues, other Telemetry, e.g. ESC RPM is working fine.
Any hints for this issue?
Thanks Martin
PostPosted: Sat 27. May 2023 11:34:01
I had this problem too long time ago - Threre is a little trick that you will get it work -
Unfortunately, this is not in any instructions - The procedure is as follows: push the two sticks down and inwards and hold them there while you also turn the scroll wheel to the right, only then will the integration window open - If you are in the forum If you are looking for spektrum and integration, you will also find a thread from me on the subject that has already helped others...
I wish you success !
Greetings
PostPosted: Sat 27. May 2023 14:12:19
Oh my god :D That was tricky, thanks a lot solved my issue.
br
Martin
Users browsing this forum: No registered users and 65 guests
