It is currently Fri 22. Nov 2024 18:29:22
[ 7 posts ] |
Uplate
Posted: Tue 16. May 2023 22:56:03 |
I have a new M4 on the way. Plan is to install a Spirit 2 with Geolink 2. I bought the kit version with ESC and servos.
Anything special I should be aware of? Motor Poles?
Thanks for any insight.
Posted: Mon 22. May 2023 11:09:48 |
there should be nothing special from other models except the motor settings. But this can be all done in the ESC.
Uplate
Posted: Mon 22. May 2023 15:11:54 |
Thank you! New GT on the way.
MichaelT1960
Posted: Thu 25. May 2023 0:57:08 |
I have just installed a Spirit 2 with Geolink V2 on my OMP M4, using a Futaba T18szh transmitter.
Still programming for the Geolink but make sure you don't turn on Stabi + Acro mode because when you get to the ground - if you move the cyclic stick it will give you a surprise (still moves and may tip over you heli.
I ruined a set of blades (ends were scrapped) until I realized why (the swashplate doesn't return to normal unless you move your stick there).
Michael
Uplate
Posted: Thu 25. May 2023 15:51:25 |
Thanks for the info. With the Geolink installed is your CG way off? Also regarding Stabi Acro I would think it should be used in flight and not on take off or landing. Perhaps Coaxial might be better if you want Stabi for that?
MichaelT1960
Posted: Thu 25. May 2023 20:32:33 |
What exactly is Coaxial stability?
Will check CG but I am using Pulse 2200 6S packs.
Still learning how to program the Geolink and Spirit 2.
Michael
Uplate
Posted: Thu 25. May 2023 20:44:17 |
It's one of the many options under Stabi menu. Good documentation in manual and app tool tips.
[ 7 posts ] |
Users browsing this forum: No registered users and 42 guests |
