It is currently Fri 22. Nov 2024 18:28:28
[ 4 posts ] |
MichaelT1960
Posted: Thu 25. May 2023 12:07:10 |
When you engage altitude hold do you also need a constant (gov mode) throttle curve so that low stick is not off?
Otherwise you would be in trouble at lower stick.
franz88
Posted: Thu 25. May 2023 14:26:04 |
the governor it just works from 51% of throttle curve to the 100% throttle curve. indeed if you go GENERAL-GOVERNOR-SETTINGS you will see that request rpm it is activated only from 51% onwards. from 50% to 0% the governor is deactivated
MichaelT1960
Posted: Thu 25. May 2023 15:03:22 |
What if I am using my own governor curve on my Futaba T18szh transmitter? Do I need to make sure it it is flat from 0 to 100, or does the Spirit 2 automatically take care of that?
Thank you, Michael
vvv850
Posted: Thu 25. May 2023 15:15:28 |
[ 4 posts ] |
Users browsing this forum: mainstreet and 32 guests |
