It is currently Fri 22. Nov 2024 19:01:15
PostPosted: Wed 12. Apr 2023 19:03:39
Hello together,
My FrSky RX6R Receiver SmartPort output is regular connected to the SYS Port to receive telemetry etc. and works fine.
The FrSky SmartPort is regulary possible to cascade with other SmartPort Sensors.
Is it possible to connect as an example a FLVSS Voltage Sensor together with the SYS Port?
I would like to connect my WiFi Link Module permanently to the SYS Port in combination with SmartPort output from the receiver via Y-Cable.
Is this possible or does this create a conflict situation with the data bus?
Greetings and thanks for help...
Mario
PostPosted: Fri 14. Apr 2023 13:56:28
Hello again,
really nobody has an answer for this?
I use Spirit GT with FrSky RX6R Receiver.
Thanks again, maybe some information from the spirit developer are welcome.
Mario
PostPosted: Sat 15. Apr 2023 7:32:55
using SYS port with Y-cable for two different things will not work.
You have to connect one or another.
Both Smart Port and Wifi-Link is communicating with different protocol so it will not work in any case.
However when S.PORT is disconnected then you can connect Wifi-Link immediately there.
Users browsing this forum: mainstreet and 73 guests
