It is currently Fri 22. Nov 2024 23:08:24
 Post subject: Flybar mode
PostPosted: Thu 08. Dec 2022 21:01:41
Hi there,
I am happy about the new Spirit System 2, though there is a question I have about the normal flight mode, i.e. no stabilization and no recovery activated.
I am flying a helicopter with flybar, and for that reason I bought the Spirit System, because it supports it, another reason is I want to have a rescue function.
So, rescue and stabilization a working fine, but in the normal flight mode there is also some stabilization applied.
What I mean is: if the helicopter mechanically nicks or rolls (without touching the control sticks), the swashplate moves to the opposite direction of that movement for a few seconds while it gradually returns to its normal position (parallel to the landing gear).
What I expected is that the swashplate would not move at all as long as there is no stick input on the remote, regardless of whatever the helicopter does.
I see that this small stabilization is required if the model is flybarless, but here we do have a flybar, and I have ticked the respective option in the menu (and saved that setting). I have also checked in the diagnosis tab that indeed rescue and stabilizatition are both disabled.
So, long text short: can this stabilization effect in normal flight mode be disabled at all for the flybar setting, or at least be reduced by any setting?
Thank you for your answer
 Post subject: Re: Flybar mode
PostPosted: Fri 09. Dec 2022 9:31:48
it can be reduced by changing Geometry 6 degrees to the lowest value.
However it will be always enabled to some extent to make the flight more stable and precise.
PostPosted: Fri 09. Dec 2022 9:50:30
Wouldn't it help reduce the cyclical gain?
Users browsing this forum: No registered users and 36 guests
