It is currently Sat 23. Nov 2024 4:07:46
PostPosted: Mon 10. Oct 2022 16:58:27
I have some questions about the stabi modes when using a "separate channel".
If I understand that correctly, then I can, for example, assign "Rescue normal" to one channel and "Stabilization normal" to another channel.
Assigning "Stabi Function" to a channel and thus activating it is apparently no longer necessary.
Can I then theoretically assign stabilization Acro, Scale and Coaxial to other channels and how can I prevent this from getting in the way?
Unfortunately, there seems to be no way to put multiple modes on a 3-position switch, for example.
When using a separate channel for the stabi functions, is it possible to make different assignments in each bank - e.g. I am switching the banks when changing the flight phases?
Thanks and best regards,
Toni
PostPosted: Wed 12. Oct 2022 18:09:46
yes, you can assign any Stabilisation or Rescue mode - all can be independently controlled with individual channels.
It is enough to set F: Stabilisation or F: Rescue in the Channels window and assign channels to them.
Stabi/Function must be set to Selected by Channel.
If you want more features with a single channel, then you can use Bank Switching and set Stabi/Function for each bank differently.
You can even turn these functions on/off if you will use F: Stabi Function with other channel.
Users browsing this forum: No registered users and 62 guests
