It is currently Sat 23. Nov 2024 3:23:58
PostPosted: Tue 04. Oct 2022 12:24:16
a question to understand Mode ON (4) at Return To Home:
does it basically save the current position every time I start without selecting any RTH mode and then does the model return to the starting point as soon as I trigger ON (4)?
That would mean that e.g. a position saved with ON (2) is overwritten with every restart.
What actually counts as "takeoff" - the point at which I activate the spirit power supply or the actual launch site at takeoff?
Regards,
Toni
PostPosted: Tue 04. Oct 2022 12:50:44
Mode 4 is completely independent from other modes. It will not overwrite position that you can program manually.
Yes, it will always use last position before lift off. No programming is needed there.
PostPosted: Tue 04. Oct 2022 13:16:08
Hello Tomáš,
saving the position therefore refers to lift-off and not to power on. Nothing needs to be pre-selected or saved; as soon as I activate ON (4), the heli returns to the lift-off position - did I understand that correctly?
Thanks and best regards,
Toni
PostPosted: Tue 04. Oct 2022 14:17:31
Yes, this is correct.
Users browsing this forum: Bing [Bot] and 24 guests
