It is currently Sat 23. Nov 2024 3:54:39
PostPosted: Thu 08. Sep 2022 14:03:39
FW: 3.4.1
Geolink V1
I have set the "F:rescue( normal)" to channel 8
I have set the "P:rescue collective pitch" to channel 9
I have set the "F:Altitude Limit" to channel 10
My Question: Is the "Rescue collective pitch" for the "Altitude Limit function" variable to Channel 9 setting or is it fix to the value set in Geolink parameter sheet for instance 55%.
Is the channel 9 value for both functions: "F:Altitude Limit" and "P:Rescue (normal)"
Thanks for your help
Receiver channel mapping 2022-09-08 14.52.51 (1).png [ 47.79 KiB | Viewed 257 times ]
PostPosted: Thu 08. Sep 2022 14:20:56
the value is for both. You can check it simply even at the ground.
Users browsing this forum: Bing [Bot] and 46 guests
