It is currently Sat 23. Nov 2024 7:58:16
PostPosted: Wed 27. Jul 2022 0:36:12
When flashing one of my units everything froze during Flash so it failed.
Unit is no longer detected. Tried the regular recovery method and I flashes fine, but unable to connect after
Made a video, https://youtu.be/ujwPNLuZGwA
Tried a support request a while ago but I guess it’s vacation time so no answer yet. Maybe one of you have an idea. Tried different computers, operating systems and cables as well. No dice. Tried recovery on a working spirit pro and that worked fine
PostPosted: Wed 27. Jul 2022 8:26:39
please send me serial number to a private message or email. Then it should be easy to fix the unit. I will send you instructions there.
You can find serial at the Spirit paper box.
PostPosted: Sat 30. Jul 2022 18:45:25
I got a special firmware that fixed my issue from the manufacturer.
Thank you
PostPosted: Sun 31. Jul 2022 2:06:50
Hi ZeXx86, I have previously tried all of your other suggestions to get my GT working and noticed that my situation is pretty much the same as this thread starter.
I have sent you my Spirit GT code if you are able to try to help with a further fix, please.
Andy
PostPosted: Mon 01. Aug 2022 10:37:34
special firmware was assigned for you.
PostPosted: Mon 01. Aug 2022 14:30:33
Thank you so much ZeXx86,
The 'Spec' firmware worked brilliantly/ now upgraded to latest 3.4.1 Firmware.
I just have to select a different, lower Com Port with this one to get the firmware to work.
Regards, and thanks - Brilliant Support !!!
Regards,
Andy
Users browsing this forum: No registered users and 51 guests
