It is currently Sat 23. Nov 2024 8:10:07
[ 2 posts ] |
pinkisoft
Posted: Sat 28. May 2022 14:00:27 |
Hello, I have installed the current 3.4.0 version and am still looking for the setting that I can use a switch and, above all, a channel to control the rescue function and stabilization. The way I see it, I always have to keep at least 2 channels for it.
Wish: on 3-way switch with a rocker switch position: - Switch position 1 (down): stabilization and rescue off - Switch position 2 (middle): stabilization - Switch position 3 (rocker switch - up): rescue function
Is it controlled via one channel or do at least 2 channels have to be used for it? The way I understand the new "assign to channel" function is that I have to use one channel for each type of stabilization mode. Unfortunately I don't have that many channels.
Thank you for your answer. Norbert
Posted: Sat 28. May 2022 14:34:01 |
you can set 2-3 functions on one channel for years already.
It is enough to use Bank Switching, set different function to each bank and set there a Negative Gyro gain in the Sensor Tab - Gyro Gain channel must be unassigned in the Channels window. Then you can change between these functions immediately just by one channel.
[ 2 posts ] |
Users browsing this forum: Bing [Bot] and 60 guests |
