It is currently Sat 23. Nov 2024 11:52:21
PostPosted: Tue 15. Feb 2022 11:34:12
Hello. I have a problem. I can't connect the Jeti ds-12 radio to the JETI Studio. The VCP driver and Bus/D2XX driver drivers are installed, but virtual COM ports do not appear in the Task Manager. When the DS-12 is connected to a computer, it is defined as a joystick and a removable disk. And in JETI Studio there is no connection with it. Tried on Windows 10 and Windows 8. Can someone help?
PostPosted: Tue 15. Feb 2022 17:28:47
it should be enough to only start JETI Studio and then connect DS-12 to your computer.
Then during radio startup select you want to connect to computer with USB.
From this moment JETI Studio should detect the radio.
PostPosted: Sat 19. Feb 2022 17:53:33
Thanks for your reply.
But the questions remained…
When connecting the Radio, I choose the USB connection.
But the connection does not occur, 1. A transmitter appears in the explorer,
but there are no virtual COM ports in the configuration window, although the drivers are installed.
4. in the lower right corner there is a red cross and a picture of a connection break.
As I already wrote in the Windows device Manager, after installing the drivers, a tab with virtual COM ports does not appear. Maybe someone has faced such a problem?
Users browsing this forum: No registered users and 54 guests
