It is currently Sat 23. Nov 2024 17:43:35
[ 3 posts ] |
Highfly
Posted: Sat 21. Aug 2021 6:19:02 |
I am having difficulties using the Spirit 2 with a Graupner HV ESC.
When I connect the telemetry cable of the ESC to the GR16 telemetry port as well as the Spirit 2 (through a Y cable) which is set as GAM, only the ESC shows in the telemetry.
When I disconnect the ESC, then the GAM (Spirit) unit shows up and I can access all the Spirit settings from the radio.
I tried connecting other telemetry modules to the Spirit and had no problem.
It appears that only the Graupner ESC telemetry connection does not play along well with the spirit unit.
Any suggestions? Does anyone have experience with this?
Posted: Sat 21. Aug 2021 8:18:35 |
please switch unit or ESC to other sensor type than GAM. There cant be two same sensor types.
Highfly
Posted: Sat 21. Aug 2021 16:12:24 |
The sensor type for Spirit is GAM and sensor type for the ESC is ESC so they are both different.
I also tried to set the Spirit to EAM but that did not work either.
Individually they work fine but when connected together, the ESC overrules and the Spirit does not show.
This does not happen when I connect other sensors such as GPS or Vario which seem to work just fine together with the Spirit unit.
[ 3 posts ] |
Users browsing this forum: No registered users and 38 guests |
