It is currently Sat 23. Nov 2024 21:12:24
PostPosted: Tue 21. Apr 2020 17:08:57
Is it possible to make new telemetry sensors for GeoLink GPS real position and GeoLink RTH position.
That would be perfect to check the RTH function in a LUA script an disable / enable RTH functionality in TX
i have
RPM [RPM] - Current RPM from the Governor.
Fuel [%] - Vibrations of the model (Reported as Fuel)
RB1V [V] - Main Battery Voltage
RB1A [A] - Main Battery Current
RB1C [mAh] - Main Battery Consumed Capacity
RB2C [V] - BEC Voltage (10x) - set Ratio 25.5
Tmp1 [°C] - ESC Temperature
5120 [μs] - Throttle PWM Value
perhaps add
GGPS[Table]
GRTH[Table]
Ciao
Jörg
PostPosted: Mon 28. Jun 2021 10:40:48
Perhaps it is possible to get the count of sats as a sensor.
I have a switch to hold position, and i only want to use it if there a enough sats
Users browsing this forum: No registered users and 30 guests
