It is currently Sat 23. Nov 2024 23:27:10
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Mon 08. Mar 2021 11:06:10
piruette consistency is very dependent on Pirouette Consistency parameter.
But generally if you have to use low tail gain, it will not work well with any value.
For tail motors it is better to start with the lowest Pirouette Consistency and the highest tail gain that is possible without an oscillations.
Then increase pirouette consistency if pirouettes are not consistent by 10 for example.
In our case with provided settings it worked pretty well also in hard maneuvers.
PostPosted: Mon 08. Mar 2021 18:23:30
Tomas, it is really not easy to check / compare paramters when there is no tool to read / compare settings.
I know the viewer is not on your priority list, but for analyzes this will be the key to do the comparison correctly.
Currently viewer is not able to read SRXL2 receivers nor it is compatible with 3.2.2 parameter sets.
Attached please find my settings, hopefully you can guide me to the parameters which really need to be changed.
I'm sure there is one mismatch in settings, easy to change, but currently not visible to me ;-)
4Blatt.4ds [255 Bytes]
Downloaded 38 times
PostPosted: Tue 18. May 2021 18:43:51
Will there be a change that all - still pending - motor tail related issues will be solved or improved in the upcoming firmware version ?
PostPosted: Thu 20. May 2021 11:36:00
I checked your settings and found that Pirouette Consistency is extremely high.
All motorized tails should rather use low value, otherwise it cant work properly.
Please set value around 80, this should resolve the problem.
Then Rudder Delay configuration to around 25 could be needed too.
We are getting pretty good results with current firmware, so I guess it will be only parameter issue.
