It is currently Sat 23. Nov 2024 23:40:16
PostPosted: Mon 10. May 2021 5:00:56
Hi Support, I need help as to why my collective pitch does not move at all.
I use futaba Sbus as receiver on micro spirit fbl. I did all mapping and found to be correct. Is there any other cables I need to use?
Thank you.
Please help
Fred
PostPosted: Tue 11. May 2021 7:32:18
does it work in the Diagnostic tab?
With Futaba SBUS wiring all the channel mapping should stay unchanged.
If collective pitch is moving in the Diagnostic tab then it mean you have enabled Rescue mode and it is active all the time. It is enough to disengage by assigned switch or gyro gain.
You can see all this in the Diagnostic tab. If Gain will be positive, it will disengage the rescue and collective pitch can move.
PostPosted: Wed 12. May 2021 12:05:04
Thank you for your instruction. Yes, you are correct. I made the changes. It caused rescue mode due to previous had set rescue mode earlier.
Thank you again.
Users browsing this forum: No registered users and 34 guests
