ZeXx86 wrote:
It could be caused by improper centering of the swashplate.
So actually 0% stick input does not correspond to 0° collective pitch.
Can you please tick Servos/Subtrim (tuning) and check that all servo arms are in the middle, swashplate is perfectly level and there is 0° between main blades at the same time?
Absolutely spot on Tomas! thank you so much! i was starting to go crazy. It was 1 spline out on the aileron servo to make it adjust enough to give 0 degree pitch from sub trim. Put a blade on one side down the length of the heli to make sure. Am now getting good throws on both inverted and upright when rescue is activated
