It is currently Sun 24. Nov 2024 4:09:05
Post new topic Reply to topic  [ 15 posts ]  Go to page Previous  1, 2
PostPosted: Thu 17. Dec 2020 20:43:49
Hi
I have checked receiver settings and it is set to DSM2/X
Trevor
PostPosted: Fri 18. Dec 2020 6:12:28
Hi
I have had some good luck, I got the unit to connect and set recovery mode and it worked.
The firmware downloaded and now the version and the firmware match at 3.2.1. All servos are now working as they should, the only thing is that now the gyros are going the wrong way.
Now I have to work out how to reverse the gyros as all servos are going in the right way so is there a section in the manual that tells you how to reverse gyros (rudder and cyclic)
Trevor
PostPosted: Fri 18. Dec 2020 8:39:02
I'd be very tempted to run the setup wizard from the start. It will allow you to make sure everything is as it should be in the correct order
PostPosted: Fri 18. Dec 2020 13:04:35
treboka wrote:
Hi
Trevor
If the servos are responding correctly to the stick movements then you probably have selected the wrong orientation for the Spirit in the General tab.
PostPosted: Fri 18. Dec 2020 21:31:43
Hi
Thank you to everyone on this forum the help you all have given is very much appreciated.
I went back through every setting and found that I had the orientation of the unit the wrong way around which meant that I had my aileron and pitch in the wrong channels.
Now that I have everything the right way around the heli is very happy and so am I, so thank you to all of the forum you are amazing, I would never worked it out on my own.
Trevor
Users browsing this forum: Rbarney and 41 guests
