It is currently Sun 24. Nov 2024 6:56:18
PostPosted: Thu 08. Oct 2020 23:16:34
I'm setting-up a Raptor 50 flybar machine with a Spirit RS/Geolink combo. All seems straightforward but to get anything like 6 degrees pitch at the relevant part of setup, the slider value is way above the recommended range of 90-150. I need a value of 200 to achieve 6 degrees, with the blades in-line with the tail boom and the flybar perpendicular to the mainshaft. It's an easy-enough setting to make with a flybarless head, but can someone confirm the same technique is needed for a flybar heli, please?
Cheers, Andy
PostPosted: Fri 09. Oct 2020 17:04:08
with flybar model you can set also lower value without any problem.
Maximally it will be only less stable.
So for the beginning you can set 100.
PostPosted: Fri 09. Oct 2020 17:32:47
Many thanks, Tomas, I'll start with 100.
So are you saying the greater the value the less stable? How will I experience this to know how to adjust please?
Many thanks,
Andy
Users browsing this forum: Storchy, The Gasman and 34 guests
