It is currently Sun 24. Nov 2024 10:54:46
[ 3 posts ] |
Alyon187
Posted: Sat 25. Jul 2020 17:35:25 |
jjuk
Posted: Thu 30. Jul 2020 20:46:00 |
The telem UNI cable (for HobbyWing 'HW') contains no electronics. Simply connect as follows:
HW Red - DO NOT CONNECT !! Remove this wire.
HW orange -> Spirit sat port, centre pin
HW brown -> Spirit sat port, outer pin.
If it doesn't work, swap the brown wire to the other outer pin on the spirit.
Wkderf
Posted: Fri 14. Aug 2020 2:34:03 |
Is connecting the brown cable necessary? or can just the orange cable connection work to send telemetry data without the brown wire? The data comes from the orange wire, and the ground connection is the same ground that comes from the other cables that go from the ESC to the FBL.
I know on other brands only the signal wire needs to be connected.
[ 3 posts ] |
Users browsing this forum: No registered users and 58 guests |
