It is currently Sun 24. Nov 2024 10:26:34
 Post subject: Probleme mit Höhenlimit
PostPosted: Sun 19. Jul 2020 10:10:50
Hello, after the first helicopter starts I have a problem.
Please help.
Geolink = height limit set to 7 meters. When reaching the 7 meter height direction
Ground the helicopter swings up and down constantly. So between 6.5 and 7.5 meters.
The settings in the geolink are acceleration 0 and rescue automatic pitch 60%.
How do I have to make the settings so that the helicopter remains calm at 7 meters?
PostPosted: Sun 19. Jul 2020 14:12:51
this behavior is correct.
Helicopter should lift up over 7 meters and then normal control is returned.
Since your collective pitch is pushing model down it will then go under the limit. And then again until you will increase the collective.
PostPosted: Sun 19. Jul 2020 17:56:39
Thank you for your prompt reply.
Will be on the next flight after reaching the cave limit
be careful.
Users browsing this forum: No registered users and 63 guests
