It is currently Sun 24. Nov 2024 10:37:40
 Post subject: Scale-Heli settings
PostPosted: Tue 14. Jul 2020 17:03:28
Hello!
I would like to install the Spirt RS in a scale helicopter.
But I'm more interested in the settings for a scale helicopter!
What is important, which settings are highly recommended!
The Scale Heli has a 5-blade rotor head, 700 size, speeds are 1000-1500, 12S Lipo, Tengu 4530 motor and weighs 7.2 kg.
I usually fly the spirit in TDF and TDR, never in a scale helicopter!
Thanks for the suggestions!
LG
 Post subject: Re: Scale-Heli settings
PostPosted: Wed 15. Jul 2020 18:46:52
I assume it is not 3D:) Setup is done in your radio to control the pitch curve based on your mechanical setup.
Having said that, the default settings would get you a stable heli and you can tweak from there.
I would suggest to use the default settings with a HH setting (initially for testing - gyro ~75) after you did your setup and initial test flight you can turn off HH to get that scale effect for flying depending on your skill of course.
Enable stabilize or rescue Normal for Stabi function - not required but could save you money...
I don’t think you need any special settings but hopefully someone else here can chime it too.
Users browsing this forum: Bing [Bot] and 58 guests
