It is currently Sun 24. Nov 2024 14:08:53
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: WiFi 3.1
PostPosted: Mon 01. Jun 2020 18:26:00
Fortune7 wrote:
ZeXx86 wrote:
Probably serial port you selected is not correct one or there is loose connection somewhere.
Spirit unit is used only for powering.
Power supply must be same for Wifi-Link and Spirit unit.
OK, thanks, Tomas - I'll check again.
Cheers, Andy
If your module was not updated to 3.0.0 then this is not fix for you.
PostPosted: Mon 01. Jun 2020 18:46:34
OK, I had success now repairing the WiFi-Link following the instructions.
Must have been some connection-fault, after reconnecting it worked!
Now I was able to flash version 3.1.
I just need to reconfigure the WiFi-Link again.
Thanks a lot, now I can flash the other one also.
Regards,
Alexander
PostPosted: Mon 01. Jun 2020 19:22:56
Fortune7: Do you think you are able to measure resistance of the resistors?
Are you powering Wifi-Link and Spirit unit from the same power supply (BEC/battery)?
PostPosted: Mon 01. Jun 2020 19:30:22
ajadda: You are welcome!
PostPosted: Mon 01. Jun 2020 19:47:16
OK, Tomas, my mistake was to power the Wifi adapter from a separate 2S battery. Now, with it connected to the BEC / Spirit supply, it works fine.
So sorry to bother you with this dumb mistake - you are very busy and you don't need idiots taking up your time!
Great Customer Service, as always!
Many thanks, Andy
 Post subject: Re: [SOLVED] WiFi 3.1
PostPosted: Tue 02. Jun 2020 21:38:38
I was able to fix the module using the pdf procedure now is at v3.1 ;)
next things to do is to remove the two resistors ... will do in the next days
thanks a lot Thomas
PostPosted: Sat 06. Jun 2020 23:05:52
today i did the resistor removal and short
and can confirm all works correctly on spirit2 too ;)
thanks Tomas
Users browsing this forum: No registered users and 38 guests
