ZeXx86 wrote:
telemetry sensors will be displayed in any case, even if no cable is connected.
Please buy Telem UNI cable, then it will work. If you have no Telem UNI cable then JST-RX without red wire will work.
So I figured out that the data wire is the grey wire and the black is the ground. Since you did not want to provide that information. I have Pack voltage telemetry. The only way for the spirit to send that to the jeti, is from the Hobbywing V4. The sensors show up in the Jeti when you turn on telemetry for hobbywing V4 in the spirit menu. When you turn off the telemetry, only i think vibe and rpm show up as available sensors. So that has nothing to do with connection as you stated. I now have to test for mah consumed and see if it works. But the assumption is if the voltage is being transmitted, then the mah should as well. I will need to test this weekend.
