It is currently Sun 24. Nov 2024 17:27:31
PostPosted: Sat 18. Apr 2020 0:53:00
Hi sirs,
My unit is uSpirit on my OXY2 with 4649T & hobbywing esc. It flys great when I use 2.7.1. :D
I just update to 3.0 about 5 days ago, and I found that the website suggesting downgrade to 2.8.
So I install 2.8 windows software and try to flash 2.8.0.4 firmware which is also downloaded at website.
When I try to flash 2.8.0.4 firmware, PC software tells me to flash 1.3.2.4 firmware, so I followed.
After 1.3.2.4 flashed, I continue to flash 2.8.0.4 and go the setup wizard flow. I select uSpirit in setup wizard but the pc software tells me that the unit is Spirit ? but it says that's fine ? So I keep setting and found that my swashplate & tail compensation is all gone !!?? What ever I re-connect the battery or re-flash 2.8.0.4, the uSpirit looks init fine but without any compensation. Could you please help me ? Thank you. :(
Best Regards,
Pu-Sheng
PostPosted: Sat 18. Apr 2020 4:22:18
Update status when I try to flash my uSpirit Back to 3.0.
In setup wizard it shows my unit is Spirt, but actually it's uSpirit.
An I got an error message here.
PostPosted: Sat 18. Apr 2020 15:22:14
the problem was not update, but something happened to the internal data of your unit.
It can be fixed easily. We will send you firmware that can fix your unit. Then it will work again with any version.
PostPosted: Sun 19. Apr 2020 3:52:33
Hi ZeXx86,
Really thanks for your quick reply.
I'll update the result when I receive your mail and firmware.
Thank you so much.
Best Regards.
PostPosted: Mon 20. Apr 2020 14:52:36
I am having the same issue. How do I go about getting the fw fix?
PostPosted: Mon 20. Apr 2020 15:08:23
Please send me serial number of the unit (displayed at the Connection tab) by private message or email. Then we can send you firmware to fix the issue.
PostPosted: Wed 22. Apr 2020 12:28:11
Hi sir,
Thanks for your support. My uSpirit come back. Thank you. :D
PostPosted: Wed 22. Apr 2020 21:54:13
You are welcome :)
Users browsing this forum: No registered users and 73 guests
